trailshredder
Thread starter- Joined
- Apr 25, 2011
- 283
Had some issues toward the end of last season on my 97 Glastron/5.7L Volvo Penta. At cruising speed the engine would cut out and stall about 80 percent of time. It would start to miss terribly and If I didn?t back the throttle down right away, it would stall. Low speeds were fine. From previous experience, I decided it was time for a carb rebuild. I pulled the carb when I winterized it last fall and rebuilt it over the winter. Put the carb on this past weekend and took it for a ride. Got up to cruising speed and did great, perfect, in fact. Decided to try WOT and it fell on its face, no miss or stall, just felt like someone hooked a barge to the boat. If I would back the throttle down a little, it would pick right up and do fine. I am wondering if the accelerator pump in the rebuild kit I ordered is too small? It came with two and I used the larger one of the two. I do not recall the numbers on it though. Does this sound like an accelerator pump issue or something else?
