Roadside Design
Thread starter- Joined
- Feb 21, 2017
- 40
Ok guys, need your advice. The boat I have been restoring was blessed with a 1959 Evinrude Starflight, the condition was outstanding with ultra low hours and beautiful paint. (Boat resto here goo.gl/0E9aNZ ). It has one flaw on the lower unit I'll address later. The great news is the engine is very clean and covered with the original white grease on linkages and perfect original plugs. I test fired it for about 2 secs when I purchased it and fired on first crank.
Now that I'm closer to running I have rebuilt the fuel pump, taken apart the carb and replaced gaskets and fuel lines, new plugs and meter tested the wires (everything was soft and flexible as new)
I've purchased new points, rotor if needed. Also still looking for a new timing belt to keep on hand.
Question on oils, I've searched but looking for recommendations and mix ratios, also the lower unit oil? My local marina insists on using new modern oils? Ive also heard conflicting info on mix ratios, what do you guys recommend?
