- Jul 23, 2011
- 53,458
....or any other "mechanic in a can"
thought I would share the quick story as summer and hot temps are quickly here
co-worker had a mid 90's GM 3/4 ton van that developed a coolant leak. so instead of fixing the issue correctly by pulling the radiator and replacing it (aluminum core, plastic tank). he poured in a can of stop leak....crossed his fingers..... then headed out of town to drive up to New Jersey from Tampa Florida with the van loaded with stuff
about the time he gets to the FL / GA line, his van falls on its face and has no power and lots of blow by.
gets truck towed home..... few weeks later replaces motor and does a tear down of the failed motor
the stop leak formed a stalagmite on the knock sensors and temperature sender, so he was running hotter than indicated, loaded while at highway speed with the crap swill you get in FL pumps and the ignition wasn't pulling back the timing like it was supposed to.
2 pistons cracked from the compression ring to the oil ring with the skirt just sort of hanging there flopping around.
morel of the story. there is no mechanic in a can. fix the issue at hand
if your radiator is leaking - fix the radiator
if your head gasket is leaking - fix the head gasket
coolant leak stoppers do more harm than good
