1986 Johnson 28 SPL fires then dies
Chris1044
Yes another one...
  • 1986 Johnson 28 spl
  • Not my engine - owner had someone else "fix" it first. One guy replaced the throttle cable, other guy removed the carburator. I have no idea what the original settings were.
  • The initial issue with it was that it was tough to start; now it will start for 2-3 seconds and dies
  • What I've done:
    • Verified 120 psi compression on both cylinders
    • Verified spark on both cylinders
    • Verified good fuel, mixed 50:1
    • Verified the plugs are in good shape (new NGK's, can't remember number) and gapped at 0.030"
    • Pulled the carburetor back apart and verified everything, including the high-speed jet, is clean. The seats on the slow speed needle and the float needle are in good shape, and the float isn't taking on fuel/sticking as far as I can tell
      • Couldn't find float settings, so I've got it set to be roughly 1" from the bowl parting line when it's in full droop...too much?
      • Found another thread on here with the same problem and the throttle plate was in upside down. Unfortunatley that's not my problem
    • Reconnected a line to the primer solenoid that was off and sitting in the bottom. This line now goes from the left (if looking at the engine facing the carburetor inlet) outer barb fitting on the primer solenoid, up the left side of the engine, into what looks like part of the intake plenum
    • Gotten the engine to run for 10 seconds or so with me manually manipulating the throttle plate on the carb,
  • Questions that I could desperately use help on:
    • Where can I get a manual?
    • What position does the primer solenoid get set to for running - not in choke mode? I've tried it flipped up parallel to and over the solenoid body, 90* to the solenoid body, and flipped down/not over but parallel to the primer body
    • What's the base needle setting on the carburetor?
    • What's the base timing setting?
The thing starts and dies, and when I pull the plugs they're wet as can be. I've fiddled around with the slow speed needle (adjusted from 0.5 turns to 2 turns out) and with the throttle cable setting (which seems to set timing via the linkage it's hooked to) with no luck. Tired of shooting in the dark.
Newyota
Believe the red primer handle points to rear of primer,not at 90 degrees if I remember correctly.high speed jet won,t affect idle as far as I know.How do you know you are not loosing spark?Sounds like your loosing spark or your flooding.Make sure the primer is not leaking past and flooding engine by removing the lines.If there is fuel in the bowl it should run for more than ten seconds regardless of fuel pump IMO.Did you check for air leaks?Did you check all grounds and for loose connections.Tons of things to check since others had hands on it.Flywheel key?Good luck.
Chris1044
Sparkplugs are saturated with fuel when I pull them, and the only way to keep it running is to adjust the throttle plate manually - which only keeps it running for 5 seconds or so. I'll try removing the lines to the primer...that's a good idea I didn't think of.
I don't think it's a flywheel key as it seems to have good lockup with the crankshaft. That said, I haven't checked it...any idea what initial ignition timing should be?
