Shift linkage
tws1616
35hp 3 cylinder Johnson tiller steer. I recently replaced the impeller.... and now it'll go into forward fine but go into reverse fine sometimes and other times I have to turn the prop. I obviously need to adjust my linkage, what's the procedure on that? I've seen explanations on here for a 2 cylinder and attempted it that way... I'm pretty sure it just made it worse. Any advice/help? Thanks in advance.
hardwater fisherman
If it shifts fine while running then everything should be ok. I think turning the prop while not running to engage into gear is normal.
That motor must be running or the propshaft must be turned in order to shift properly ...That is a fact.-------But is there a chance that the upper shift rod was turned during the work , yes or no ?-----Is there a chance that the lower shift rod is not fully turned into the lower unit , yes or no.
tws1616
On the first yes. On the second yes, but in my reading I found I needed to turn/screw the rod completely into the lower unit and did so.
When adjusting do I need to have it in neutral or reverse?
Answer the question /s.-----------At the powerhead there is a detent / spring loaded ball. Is the motor in nuetral when that is clicked on that detent.----------If the upper shift rod turned than the gearshift will be out of adjustment.-------------That does not occur on 2 cylinder models , only on the 3 cylinder models.----------Up to you to tell me if the lower shift rod is now fully turned into the lower unit.-------------The upper shift rod adjustment is done with the lower unit OFF THE MOTOR.----------I do not believe the measurement needed is found in any manuals either !
tws1616
Thank you. I did answer both initial questions with a YES. I also stated that I did turn the lower rid full into the lower unit after doing some reading.
As far as the detent/spring when in neutral I have to barely touch the lever forward in order to get the motor to turn over.
I've got a manual but it gives no instruction on how to adjust, at least none that I found.
Thanks again.
Oh well, If the motor was in my hands I could sort this out in a matter of minutes.
tws1616
Is something getting lost in translation here? I'm undoubtedly new here, but is my answeRd not coming through? I come here asking for help and have made attempts at answering the questions you've asked... I'd be much appreciated for the help... of you don't want to help I understand and I'll go elsewhere. But I ask again am I missing something here?
