Seahorse 20 HP revving high
biggle
Hi everybody. I recently purchased an old 14 foot aluminum boat. It has a Johnson 20HP seahorse (late 60's or 70's model), electric start, with a steering console forward/reverse and throttle levers. I have taken it out twice now, and each time it ran well for several hours and then started to have issues. The first trip I stopped it to drop off a passenger, and when I started it back up it began revving really high and I was nervous to try putting it into forward, so I didn't. On the second trip, I was trolling around and decided to call it quits for the day, only to have it die on me as soon as I revved it up. Upon restarting it again revved really high and had to be shut off by the kill switch on the engine housing. Each time I waited 10-15 minutes and restarted, but the issue did not resolve. Both times the fuel was close to empty but should still have had enough to fire up. I asked a local small engine mechanic and he mentioned that some of the old 2 stroke motors would rev high when fuel got low. Have any of you heard of this? He also checked to choke and didn't think it was stuck.
My next question is how fast should I expect this engine to get my boat going? Using tomtom GPS I have maxed out at about 11 mph. (with two adults and the usual supplies on board) That same mechanic thinks I should be upwards of 20 mph. It's not that I want a speed boat, but I live next to a very large lake and it would help me feel a lot better if I could get off quicker when the wind picks up.
Thanks for any help. Also, my outboard knowledge is basically zilch, but I am willing to learn. ;)
oldboat1
There's a stainless spring clip that connects the throttle to the mag plate (pn 0316362 or similar -- think that's for a 10hp). It's up at the top of the throttle tower -- connects up the linkage. If that popped off, the throttle/timing plate can be in a wide open position (or at least advanced position), and will be unresponsive to twist grip control. Could be that.
F_R
At 11 MPH, it should be making at least a good effort at leveling off onto plane and should go faster. The motor might be running on only one cylinder, may be terminal sick, controls may not be giving it full throttle---stuff like that. OR, the problem may be the boat and load. I guess the first thing you should do is check to see if it is running on both cylinders.
biggle
Would that still be the case if I am not using the twist grip control? I only use the two levers up by the steering console.
biggle
I talked with a different mechanic and he says it sounds like vapor lotck. Hopefully that's all it is.
I check both spark plugs and they appear used, so I think both cylinders are firing. My next fix will be figuring out what position to put the prop at. There are four holes, and it is currently in the second hole closest to the boat.
Never heard of vapour lock on one of those motors !----The shaft between the throttle gear and the magneto plate.-----Find it and look on the bottom of it.---There is a nylon / plastic piece that may be broken.----?----You think both cylinders are firing, but do both leads fire a spark across a 1/4 ' gap or better.-----Very simple motor that sounds like it needs a bit of trouble shooting.
Newyota
My 1985 20hp on my 14ft aluminum Jon and two people and gear goes 24mph ,so you are very slow.Sounds like a lot of things may need checked to be sure.
oldboat1
Some parts diagrams here: http://www.iboats.com/20R71S/dm/cart...iew_id.1532558 Should look for a manual as well. (Get an adjustable spark tester at most auto parts stores.)
Your throttle cable may be the old style with two screws clamping the inner wire. One or both of the screws for your cable may have worked loose -- or there could be a problem with the connection in the cable box. Result would be that operating the remote lever doesn't reliably operate the motor throttle. (If the motor throttle is advanced, your slipping cable may not permit you to throttle down with the remote lever.)
The approach is always to unhook cables at the motor, and first make sure throttle and shift functions are OK at the motor -- then examine the cables and the cable box. Adjustment and reassembly is the reverse (match cables to motor, not the other way around.)
