Johnson j150stlcca with air leak in crankcase
Chuckdeezel
I have a 1988 johnson gt 150 that that has been running a little lean and ruff at idle. Also when i accelerate it takes a while to plane ( 8sec on 17ft bass boat) and wot is around 4400 rpms. So today i checked for leaks. I took a soapy sudsy solution around everything to check for leaks. The crankcase halves on both side where pulling in suds in a couple spots. Maybe that's the issue? How hard will it be in terms of do it yourself?
rebuilt
1st, you've come to the right place. Crankcase leaks could cause the problems you describe. Lean. 2nd, to reseal the cases, they need to be split, cleaned, like surgically clean, then reassembled. Maybe there is a shortcut, if so, this is the place to find it. But to really properly reseal those cases is no small job. Powerhead off, cases split and cleaned, then put back together. I just did this on an 89 3cyl 60hp J/E 2 stroker. Mine was a labor of love, if you will, but no small job. A real J/E manual for your motor would serve you well. Seloc will do in a pinch, but there's nothin like an oe manual. Hope it goes well.
Chuckdeezel
Well there isn't a shop around here that will work on it right now. So either I do it myself without experience and an engine puller, or wait until off season and pay someone 100 bucks an hour, or figure out a shortcut. If there is a shortcut it is sounding good.
First thing I would do is replace the bypass cover gaskets.----Inspect pistons / rings at the same time.
