Johnson 40hp tilt assist
Trout Guy
Hi I recently bought a boat with a 1998 Johnson 40hp outboard on it. The factory tilt assist is not functioning, when I put the boat into reverse the motor comes up on the water when I give it throttle. The boat has a CMC electric trim and tilt that the motor is mounted to so I really don't need the factory tilt assist. I was wondering if there's any way to do without it. I was thinking of some sort of turnbuckle to make it not tilt on the factory pivot mount.
Any insight or suggestions are welcome!
I have the same setup. You should have a tilt/run lever, you could just leave it in the run position. I leave mine in the tilt position in case I bump something.
PhrozeN_FisH
Does it have the tilt pin installed to allow it to lock in the down position?
rgs1
I have a Evinrude 48 spl which has the same setup. When I got he boat the tilt assist cylinder had already been removed. I have just mounted a CMC trim tilt on the boat. For the motor I mounted a spring between the pins where the tilt assist mounted. The spring I used is the same one that CMC uses for this bracket http://www.cmcmarineproducts.com/pr...CMC-Tilt-and-Trim/CMC-BA-130-Break-Away-Mount. I purchased the spring direct from CMC for about $20. I haven't had a chance to test it yet but it appears to be promising. I will try and post some pictures latter..
