Setting the timing on a 4.3 262 Mercury
eddiemako1
Here's my problem. on the vibration dampener there is a line cut across. on the timing cover there's just a notch. there are no degrees on the timing cover do I just set the cut in notch? I tried to upload a picture but it doesn't seem to want to. Timing supposed to be 10 degrees BTDC
solar7647
What is the year and serial number of your motor. Depending if you have the TB4 or TB5 ignition, the timing proceedure is different
eddiemako1
Model number 4211025PS serial number om3 55255 the boat is a 2002
eddiemako1
I'm sorry my dyslexia got the better of me. I typed in the wrong serial number. The correct serial number OM 355225
eddiemako1
No Title
This is what my timing cover looks like
Gen VI front cover. You need to follow the TBV timing procedure
achris
More fish than mountain goat
And use an advance timing light... There is only one notch on the timing cover and one line on the pulley. That's TDC... Use the advance timing light to set it up at 10 BTDC...
eddiemako1
I ended up getting timing tape for the correct size harmonic balancer. And set the timing thank you for everyone's help
