oldboat1
- Apr 3, 2002
- 9,612
Yeah, really not much to check -- if the type with a screen, can unscrew the screen and make sure there is no blockage. I would just do the primer pump test, and if that keeps the motor running I would figure on replacing the fuel pump diaphragm. It doesn't have to be holed -- can be old and taken a set (lost flexibility). Sort of like old boaters....
Not emptying the bowl would indicate a carb issue -- maybe a nozzle gasket if your carb has one, or maybe a vent issue (not feeding). That means pulling off the carb, soaking it and opening all passages, checking for assembly, etc.
