The four cylinder engines only have one bearing and the snap ring holding the shaft in the housing is accessible from the rear. Access to the forward snap ring and seal is the same whether the engine is removed or not. Wondering why people recommend engine removal for this. Is it so the shaft can be hammered out from the forward end?
I can understand the shaft being hung up on the flex plate if rusted together, and that would be a reason to get penetrating fluid onto that spot. You would need to remove the engine, or go through some acrobatics to separate engine from the flywheel housing if that were the case, And for this particular instance with the likely hood of water in the housing, it would probably be appropriate.
But for a normal bearing replacement, on four cylinder engines, don't understand why people recommend pulling the engine.
We are getting off topic I'm afraid.
The shaft cannot come out the aft end until the three parts behind it come out.
The shaft has a step in it (page 91 of the manual).
It "normally" would be pulled out towards the front after the shaft snap ring is removed.
The three parts are seal, bearing snap ring, bearing.
The bearing is PRESSED in from the stern.
There is no way to get a bearing puller on it with shaft in the way.
Now, if one could make a splined shaft holder strong enough to grab the shaft and pull it out, it would(maybe) pull the bearing.
Perhaps there is an opportunity here, maybe I'll invent a tool before all these older boats disappear.
Another couple of reasons to pull or raise the motor.
Clean out the bilge, replace rear main seal, replace oil pan gasket, flex plate and pilot bushing inspection, rubber center support bushing inspection
| Rubber Cushion | 804210 | 1 | Obsolete part) |
Just my opinions and experience on my previously oil dripping boat.
