1969 Johnson Hydro-Electric timing advance sticking
Washington Sage
Good morning all, new to the forum here. I've been lurking for a while but just joined.
I recently acquired what I believe to be a 1969 Glasspar Citation with the afore mentioned Johnson 85. The boat in pretty much in order now but I have an issue with the engine that has me scratching my head...
So, under cold start conditions it will start with little coaxing and run great for 15-20 minutes. But after this it starts to exhibit "sticking throttle" symptoms. Even moving the throttle control back to neutral position it will continue to cruise around the lake at about 1/3 power until I kill it with the key. It is then extremely difficult to restart and only runs a few minutes before shearing the flywheel key and dying.
Both times this has happened I pulled the cover and examined the throttle components and find they all operate smoothly...but find the timing stuck near full advance. I have disconnected the advance plate from it's linkage and found that the linkage moves freely but the plate will barely move.
I have dissasembled the entire mechanism, cleaned and lubed it...moves freely when cool but binds when warm. I can find no evidence of contact or wear anywhere on the plate or nearby components. The advance plate assembly rides in a large (roughly two inch) bushing that appears in fine condition and I have cleaned and lubed with a light coat of grease.
Any thoughts or advice would be greatly appreciated, thanks in "advance" ;-)
F_R
It is supposed to be installed with a couple of drops of oil, not grease. And it is a very close fit, so it cannot tolerate any dirt, roughness or burrs.
oldboat1
Flywheel nut torque? (believe correct torque would be100-105 ft lbs.)
I do not believe flywheel nut torque affects the timing on a 1969 model.
oldboat1
believe he also mentioned shearing the flywheel key as well? (couple of times, sounds like....)
Washington Sage
Good info on the the bushing oil, I will re-clean that and apply a little medium weight oil.
I got my hands on the factory service manual today and the flywheel nut torque spec is 70-85 ft lbs. I was going to 100. But both tapers are a little rough. I have cleaned them every time but will lap them tomorrow. Hopefully that will fix the key shearing issue.
As far as the advance plate sticking, this arrangement would not be effected by the flywheel nut torque. Unfortunately, I don't know yet what it would be effected by...
Also for your consideration, the first time I took the distributor cap off (before I discovered the advance issue) I found that someone had placed soda can spacers under each of the screw locations suggesting that they were combating this issue. Apparently thinking that there was contact between the cap and the advance plate. There is not. I removed the spacers. However when I did realize the issue I replaced the spacers and found the issue to be worse. :-/
I am simply at a loss as to why the advance plate would bind like this. I will try it tomorrow with just a little oil on the bushing.
boobie
I ran into your situation years ago and all I can remember is I ended up taking material off of the mag plate with a Dremel tool to cure the problem.
boobie
That was in the distributor cap area. Wish I could remember more. TFO.
oldboat1
re. flywheel nut torque -- set it to what you see in your service manual.
F_R
No Title
And the correct answer is 100-105 foot pounds. See the service bulletin.
