Kimberly80
Thread starter- Joined
- Aug 7, 2015
- 13
My ex left a johnson 1974 40hp model number 40rl74s in my building. after i went thru the motor and got it run, I noticed the head was getting too hot.
Its not circulating water . I put a new impeller in the l.u and drill tested it while in a bucket before reintsall
I made sure to install a new o-ring in the intake tube also. Reinstalled the l.u and still no water comming out of the exhaust relief port, my motor doesnt t-stat... here are the things I've done...to keep it short.
1)put a water hose on the intake tube that's connected to the powerhaed and get good flow outta the head.
2) removed the water cover from the cylinder head. Started motor only drops of water and exhaust comming out of the water passageways .
3) I replaced the head, headgasket, water cover gasket, my compression is 110 on both cylinders.
I then start the motor "in a barrel" still no water is comming out. Btw..the water level in the barrel is 2" below the exhust relief port.
If I remove the little cover on the were you unscrew the shift linkage water starts to spray out the exhaust relief port and the head immediately cools ....
Only other cause would be the mounting gaskets or a cracked intake tube? Anyone have thoughts?
