Watermann
- Jan 12, 2013
- 13,853
For a livewell you need a pump then not just a fitting, the pump has a long shank that passes through the hull that you can either cut to fit or push the pump forward out from under the transom. I put mine in the open area next to the bilge drain plug, plenty of room under the transom wood and you just have the aluminum to bore through. Also get a strainer so gunk doesn't foul the pump impeller.
Pic of what my livewell pump intake and drain looks like.
