First vintage Johnson 15hp
catch47
Good morning all..new member here. I have recently purchased a 15 hp Johnson. Seller painted the entire motor black. He is guessing it is a 1956. There is no transom bracket tag. So i am looking for some guidance if anyone can help by picture identify year and model. It runs, but rough, leaking gas from the high speed adjustment screw. I plan to do points and a carb job.
Thanks in advance for any info. Advice welcome as well. Unfortunately i am unable to upload pics until i post 3 times and then learn to resize them
I believe 1956 was the only year they marketed that style of motor.---------Motor block was originally a maroon colour.----Easy to check for that.
catch47
Yes, definitely maroon motor. Very clean inside. Just making sure, want to find the right points and carb kit.
catch47
Thank you for the link. So youwould agree that it is a 1956 and the model is FD? is it FD-10 or anything like that?
Crosbyman
No Title
I have a FD 10 same color but 2 line pressure tank I converted to pump... Experts like FR can be more specifc since ypour's has a pump on a bypass plate.
flyingscott
Looks like somebody drilled and tapped a nipple into the transfer port cover. Somebody already did the conversion to a fuel pump which is nice.
1956 is the only they marketed it as a 15 HP model.-----57 became the 18 hp !!
catch47
Thank you guys very much for your help. I am already on the road to a tune up. It runs, shifts . But its a bit rough, leaking gas around the high speed adjustment screw. Carb kit on the way.
TN-25
I agree that 1956 was the only year for that style of Johnson in 15 horsepower. Looking at your hood I see 2 holes where a front oval emblem would have gone and front faceplate (where the choke & mixture controls are), making me suspect that either a 57 hood is on the motor, or it is in fact a 1957 18. Look on the welch plug on the engine block to see if you can find a model #.
It is funny, but Gale revived and kept the 15 going from 1960 through 64 in Canada, then repainting them & calling them Johnson Workhorse 15 or Evinrude Worktwin from 1965-68
catch47
Is that the same as the freeze plug on the side with the sea horse emblem? that number is 1641729.
If not, ill take a look tonight. getting ready for carb tear down. I dropped the lower end oil and it was chocolate milk so i am going to do th ewater pump and all the lower gaskets. But i better find out for sure whether its 1956 15hhp or a 1957 18hp..lol
