1969 6hp fisherman no Spark
jonsilva
I have a 1969 Evinrude 6hp, when i first ran the motor it would run but had no power. After taking a look at it i realized i had no spark in the top cylinder. i have replaced both coils, condensers, spark plugs and the spark plug wire on the bad cylinder. i have st the gap on both points to 0.020. I still have no spark in the top cylinder and i have no idea what to look at next.Any suggestions?
F_R
All I can tell you is that assuming the coils are good (they should be, since they are new) the great majority of no-spark problems are caused by breaker points not making good contact. I notice you didn't say you replaced them. But even if you did, even new points need to be cleaned. If they are the old points, take them completely apart, degrease them, and polish each contact shiny bright. Then reassemble and set to .020"
Are the COILS properly adjusted ?--------Did you remove magplate and the wires to properly insert wires into the replacement coils ?------Yes make sure the points are clean.
Crosbyman
did you try swapping things
can you at least see continuity to ground on the bad spark lead
did you use solid metallic wires (not carbon resistive type)
​did you properly set the wires in the coil (screwed in)
tried another spark plug ?or swap them
just as a test ... remove the condenser
jonsilva
had no continuity on the one wire so i put a new wire and got continuity still no spark,
Many questions were asked and it is important to answer.----------Carbon core wire as in automotive or wire core wire ??----Answering the questions helps you !!!
RCO
Did you set the points at the high point on the cam? Lots of people have mistakenly set them where the cam is marked "Top". That is just to indicate that it is the top of the cam, the set point is usually in line with the keyway. Are you using a spark tester, or just resting the plug against the block? That motor needs a solid core wire, and a Champion non-resistor plug. Anything else will cause you problems.
jonsilva
not sure of the core of the wire but it was a marine spark plug wire., i did everything the same on the one with no spark as the one with good spark, the only thing i did not do was clean the points. i have champion plugs, at first i was testing be touching the plug to the block but then i started using the spark tester. i will rest the points at the high point inline with the keyway tonight
F_R
Clean the darn points!!
