rpm gauge?
kentuckybassman18
my rpm gauge on my bass quit.what i done i took off on my boat and had the motor up to much and the rpm gauge quit. so i went and got a new rpm gauge and it will'nt work.i hooked it up just like the old rpm gauge.the rpm gauge is not getting any power to it. could it be the rectifier bad? what does a rectifier do anyway? or could it be something else bad? so please help... thanks.... :confused:
Kesh
Re: rpm gauge?
I have just re-built my instrument panel and learned a bit about the gauges. The RPM gauge (in my case) has ground connection and a +12V connection (the 12 volts provided by the ignition switch). So you need to make sure the gauge is being powered. Then, there is another connection called "pulse" which is the actual signal coming from the alternator of the engine. The back of the gauge also has a knob with a dial consisting of numbers (2p, 3p, 4p , 5p and 6p) where you must select the appropriate number according to the number of magnetic poles of your engine's alternator. In my case, as it is an OMC 225HP, the guide says to position the knob at the 6P position. You must read the installation guide to determine the proper position for your engine.<br /><br />There are also two more connections to provide electric power to the small instrument ilumination bulb.<br /><br />The teleflex website contains good info (troubleshooting and installation guides for all common gauges). Here is the link to the tachometer installation guide: <br /><br /> http://www.tflx.com/PDF/99320.pdf <br /><br />Hope this helps.
