cbelaire2334
Thread starter- Joined
- Mar 28, 2017
- 5
I recently bought a 1978 55 HP Evinrude Outboard and I'm having an issue I haven't been able to work out. When I bought the motor the first things I did was have the both carbs pulled, cleaned, and rebuilt. Other things I've worked on/replaced that may have something to do with the problem include:
1. New portable fuel tank (vented)
2. Installed an in-line fuel/water separator (not currently mounted to the transom/gunwale)
3. New fuel pump
4. New Battery Cables from battery to block/solenoid
5. New Starter
6. Throttle body pulled, cleaned, rebuilt
7. New throttle and shift cables
8. New spark plugs (gaped to manufacturer requirements)
The issue I am having is when I go to accelerate past the low speed carb (regardless of how warm the motor is). When I accelerate the engine is starved for fuel. I can use the electric choke located at the control box to increase the gas flow and get the motor to run at higher speeds. I just barely have to use the choke. If I engage the choke for longer than just a quick tap the engine it dies/floods. Once I get the motor up to speed it will stay at speed and runs well. Also, once its at a higher speed I am able to slow down/accelerate small amounts with no issues. I've also noticed now that it is warmer, starting the motor takes some time. During the winter months (hunting season) I figured I was having to start the motor multiple times until it warmed up but it's still dying (starved for gas?). I'm sure I could just increase the idle speed to combat this but I have tried to avoid making adjustments like that until I know all components are functioning appropriately.
If anyone has any ideas of where I should start, I'd appreciate it.
3. New fuel pump
5. New Starter
