NEED SOURCE to buy grease zerk. Anyone purchase one recently??
crazy charlie
Need a replacement zerk for my 1988 alpha setup.I ask if anyone has purchased one because I have already tried to get one in just about every place that will be recommended.I thought it would be a simple part to get.Even tried local boneyard only to find they have closed and moved.I have heard all the excuses...we dont stock them,we are out of them,cant get them,We can order them for you(so i ordered it and it never showed up).Dont want an automotive type because of a stray current issue in our marina.Cant take the chance of a different type of metal .Gonna try an outboard supply house next.Cant believe this.Anyone....????
Bt Doctur
Your kidding right?
they dont make cast iron grease fittings. stray current is NOT an issue inside a dry bellow anyway.
bruceb58
The search works fine. Just look down past the math solution.
crazy charlie
the Zerk is for the trim.One on each side of the bellhousing.Same as the one for the gimble bearing.
crazy charlie
Auto parts stores dont seem to carry stainless ,just the cheap stuff
crazy charlie
Thanks stony ,yes that is the correct part # just can't find one..?Lol I feel like a newbie posting something that should be this simple
crazy charlie
You da man Bruce!! How the heck did you find it.I did every search I could think of ,grease,zerk,fitting,grease fitting,mercruiser grease,yada yada yada.I would never have searched on "Engine fitting kit" thanks
bruceb58
Just searched the part number on ebay just like I did in post #3
