1987 Johnson 50hp idle
Chrishaglerr
Hey everyone, so Im having trouble with my 1987 50hp Johnson not idling. I have rebuilt both carbs (cleaned them well and even used compressed air for the jets), rebuilt the fuel pump, replaced all hoses/lines and connections and even the primer ball, new water fuel separator, and the tank is fairly new.
Now for the problem... It will idle if I keep squeezing the primer ball, and runs GREAT at higher RPMs/speeds without pumping the ball or anything, but if I don't pump that primer ball while idling, it seems like the carbs run dry and it shuts off.
Now I have tried an external tank to rule out any clogging in the lines on the boat even though they are new, and it does the same on the external tank (have to keep squeezing the ball).
I want to say its the fuel pump but I just did a rebuild due to this problem and it didn't solve it. Gas is 50:1 oil/gas ratio so fuel isn't a problem, all fresh fuel.
What could be the issue here? Should I buy a whole new fuel pump? I know I did the rebuild but it was pretty much only the gaskets...
Thanks
The fuel pump runs off the CRANKCASE compression.----Doing a compression test on the cylinders MAY provide a clue if there is something wrong internally.----Post the numbers.
juno pierrat
check compression, numbers should be close, 10% of each other, please post numbers not just "their good",
maybe suction leaks letting air in system, not clogged lines
