Thinking about switching over to electric fuel pump on my Johnson SPL48. What will be the right fuel supply rating for the pump? 2.5-4 or 4 -7- GPH?
Why? What is wrong with the original pump? Adding an electric will require some way of cutting power to the pump if the engine is not rotating. Four stroke engines can utilize oil pressure to verify the engine is running.
Sure, check the antisiphon valve for blockage. Check the fuel tank pickup for cracks. Check any splices in the fuel line for air leakage.
David, Just so you know, Mercruiser started using electric fuel pumps on their carb engines in the 90's. They used a relay to kill the voltage to the fuel pump, if the engine stalled.
