50 hp evinrude torque question
1971Evinrude50hp
so this is my first rebuild and i don't know much about torque and torque wrenches. but the appendix for my service manual says to put in the main crankcase bolts and head bolts to 240 lbs. At the top of the chart it says to divide by 12 to get ft. lbs. So that means that the main crankcase bolts and head bolts only get tighten to 20 ft.lbs? that seems awfully low. also the same chart says to tighten the fly wheel nut to 2400 lbs. so that would be 200 ft. lbs which seems right. so my question is do you really only tighen the crankcase and head bolts to 20 ft lbs? i got a torque wrench today and want to make sure i do it to the right number.
F_R
You are correct, 12 inch pounds equal 1 foot pound. If you are working on a 1971 50hp as your name suggests, those numbers are not correct. Better double check.
These are the facts !!--------240 inch-lbs ( 20 ft lbs ) is correct.-------Flywheel nut is 105 FT LBS-------It seems you are not working from a factory manual.------Some after market manuals belong in the wee house with the 1/4 moon on the door.
Bosunsmate
Many headbolts are around 20ft pounds, but remember thats on clean threads on bolt and in casing.
Its being a while since ive done crankcase bolts so cant recall that but i do know ive never done anywhere like 200ft pounds on a flyhweel. My 60hp is only 100ft pounds and a 85hp i did the other day was that too. Too much torque and you will strip your crankshaft taper and itl be out of balance permanently thus stuffed
interalian
Stuffed? Haven't heard that for a while. :)
