Johnson JW - 21E Point Gap
brunof399
My father is working on an old Johnson JW-21E 8HP motor. Does anyone have some information on adjusting the points and coils? Thanks!
That is a 3 HP motor.-----------Search for ----universal magneto---------------To get lots of into.--------Point gap is 0.020"
brunof399
So, my father was able to get the motor started thanks to the information you all provided. Just a little background, my dad is a retired master mechanic who used to work on heavy diesel equipment at a scrap yard. This motor was junked there and no one knows the last time it actually ran.
He was trying to fix it to give to a friend....but the problem is, he is becoming attached to it!!!
He does have another question - is there any information on how the lower unit (from the water pump to the propeller) gets lubricated? I'm not sure if I am even asking the question correctly but I think that is what he was getting at. Thanks again!
there is a spot to fill the gearcase with outboard gear oil.
Vic.S
The gear case should be filled, as racerone says, with an outboard engine gear oil. On the side there are two broad headed screws, one at the bottom and one near the top. These re the drain/fill and level screws.
Remove both. Watch out for the sealing washers ( which should be renewed ) and drain the old oil. If there is water in it or it is excessively milky in indicates that the other seals may need renewing.
Refill via the bottom hole, to prevent air locks, until oil flows from the top one.
F_R
Actually, that motor design came out in 1952 and was made for many years, both Evinrude and Johnson nameplates, including 1966 JW-21. Among the most successful outboards ever built.
EDIT: Well OK, the 1966 has a different mid section, as part of evolution. But no big deal. Some people do not think much of the single transom clampscrew. It's a good idea to use a safety chain or rope to fish it back out of the lake, just in case
