1976 evinrude 25602E
Thereeds2004
So I got this motor from my father in law and he said it ran I did everything under my power to get it going but it's a no go I went and bought everything I could think of and finally got to the points and after looking and looking I think I am missing some things under the flywheel.
Now I know nothing about motors at all so explaining to me in stupid terms is best. Here is what I what going on
Motor cranks
Tested compression 150psi on each cylinder
Test spark on each plug nothing
Removed flywheel and cleaned points
Ordered new points for a incase
Pic of under flywheel shows only one magnetic thing not two like I am seeing online
Any help would be good to get this going
boobie
The thing about this mtr is that the points have to be set correctly and VERY clean.
Vic.S
Motor cranks
There is only one "driver" coil under the flywheel. The ignition coils are separate.
You motor is covered by this manual http://boatinfo.no/lib/evinrude/manuals/1971-1989johnsonevinrude.html#/0
Diagnose the problem before you start buying random parts or you will soon spend all your beer tokens and still have a non running engine
There is a good troubleshooting guide on the CDI electronics website http://www.cdielectronics.com/support/
Thereeds2004
Would it be best to just take it to someone that can work on this. Like I said I have no clue what I am doing I am just poking around trying to figure it all out.
As far as a kill switch not that I know of
flyingscott
That motor is not beyond you the hard part was pulling the flywheel. Put up a a pic of the front of the motor make sure you new condensers also.
Thereeds2004
Ok I got the points set and back together now I am running into a problem the boat does not want to start. It will crank and crank but will not kick over. I have good spark now on both plugs, good fuel, and great compression 150/150 what am I doing wrong on this
flyingscott
Are the plugs wet with fuel? Was the flywheel key in good shape when you reinstalled it
Thereeds2004
Fly wheel key looks good and the plugs look to be a little damp after cranking in it for a few minutes
flyingscott
Those plugs need to be more than damp after cranking for a couple minutes. If you had the choke on you should almost have fuel running out the exhaust.
Thereeds2004
There is fuel running out of the exhaust and the plugs are wet. And I am testing spark two ways with a spark plug tester and also took them out and tested it by holding it next to the motor and visually seen the spark jumping from the plug. Where we live here in Mississippi we don't have much options for someone to work on boats closest place is about 80 miles from my house
Is the spark capable of jumping a gap of 5/16" , yes or no.--Very important to answer that.
Something is wrong here.---------You have posted that you have proper spark.---------Plugs are wet with fuel.-----Said that compression is 150 PSI.----------Therefor the motor should run !--------Perhaps plug leads are on wrong cylinder ? But motor will usually bark loudly if that is the case.
Thereeds2004
Correct this is what I was thinking to. It has proper fuel 50:1 mix and everything that I can think of and have tried from reading here and online has been done this Motor should be purring like a kitten or at lease running like a rabbit ape
When was the last time that this motor ran ?---Did you see the spark jump a gap of 5/16" , yes or no ?
F_R
There is such a thing as too much fuel. It's called "flooding". Wet and running out seems to fit the description.
oldboat1
Water in the gas? Too much oil? (Need 50:1 -- about 3 oz. 2-cycle oil per gallon of fresh gas.)
Thereeds2004
I gave up on it and took it to a boat place and he got it going. Apparently these motors have to be set correct on everything with no play. He adjusted the air to fuel screw and set the points dead on. Took him about 30 min and he had is going. Paid 50$ but it was money well spent I will be putting it on the water tomorrow to see how it does
