dreese2005
Thread starter- Joined
- Aug 21, 2010
- 34
So I have to say..Thank you and I have learned a LOT from all of the posters on here.... I am close and I mean real close to having this thing right... At this point I know it has to come back apart and I am ok with that... Its a learning process for me.. here is the last issue... After now rings and honed cylinders I put everything back together.. asked a lot of questions.. Got a lot of great answers.. found out it is best to buy the manual... check... Learned that you cannot guess at the timing no matter how good you are...lol buy a timing light... check... So I did the timing with all plugs out and full throttle... guess what... it works... idles and runs much better than I have ever seen it do... so here is the last question before I tear into it again to RE-SEAL the crank case.. Popping as in idle idle idle idle idle pop idle idle idle pop die... When it pops I could see a spark coming from the bad seal job on the crank case..So I know it is firing inside the crank case.. question is.. why? is it because of the bad seal and sucking air? bad seal that doesnt allow pressure to build up in the crank case? other issue causing it to fire inside the crank case that has nothing to do with the bad seal? Like I said I am going to tear it apart again to seal the case but want to know if this is causing the problem or if I should look for another culprit while tearing it down again... AGAIN, THANKS TO EVERYONE for babysitting me through my first outboard teardown...
