jimmbo
- May 24, 2004
- 14,629
Usually this engine runs very smooth, starts within 2 seconds unless it is colder than -18, then it takes about 4 seconds. But... Some days on first start, engine occasionally would seem like it had flooded, like a stuck injector had drain the fuel line overnight. Holding the pedal to the floor would give the impression it was trying to catch. When I would let go of the key the engine would stop, then proceed to diesel backwards a few revolutions and some whitish vapour would appear from the grille where air inlet was. Two weeks ago during the cough cough cranking stage, there was a very loud back fire and a bunch of white vapour came out from all around the hood. Engine started. Took it to my cousins shop and told them I figured I had an injector that was draining the rail. Well the backfire blew the valvecover apart and pushed the gasket out. None of the plugs were fouled, but I did put new ones in. They were 8 yrs old and 80,000km(50,000 miles) and had a gap about double the .050" spec. So far it hasn't done the hard start again, nor is it missing or misfiring while running. Oil wasn't full of gas either. The engine is a Chev 2nd gen LT1
