89Aluma
Thread starter- Joined
- Aug 23, 2016
- 89
So I bought this cheap 56 Johnson 30hp rd-18 wound up being 57 evinrude 35hp rd-19 the guy said it started easy needed a water pump he only ran it for less than a minute. Anyway I picked it up for little to nothing. I had trouble starting it had put a little gas in the cylinder and mess with the armature plate and it started up, ran well but after Erving it just a little bit above the start position it started to spit and sputter for a bit I figured it was a carb issue so I cleaned the carb and it was already very clean. But now that I've had some time to investigate this engine a little I found that the armature plate wolbles just a bit, side to side, and when at full throttle, engine off, the plate stays in place but when on the mid range i can move it by hand pretty easy, also when turning the flywheel by hand it moves the retards the timing a little which is why I think I'm having the starting issue it has good spark coils have been replaced condensers look brand new and the points are set perfect I link and synced it so that the line on the throttle plate the touches the rubber roller is at the pointer mark at the exact same time the butterfly valve starts to open. Then I was looking at the armature plate in frustration I realized I never check the crankshaft end play on this motor so I grabbed the flywheel and I can feel it move just a litttle and you can hear a little thunk noise when you yank on it with some effort to me this is bad news in a car engine but but I've never worked on a motor of this age what's normal for that tolerance? Is the slight wobble in the armature plate worrisome? Could it be causing my hard start issue? If so what would it take to rectify the issue.
