Volvo Penta SX/Cobra pivot housing Seal?
mtaboat
Is their a seal (other then the water pump) that goes between the pivot housing and the transmission on a Volvo SX drive?
Fun Times
Nope.... All you need to install the drive unit is the inlet water O-ring which is number 29, http://www.volvopentastore.com/Uppe...*****.853195591--store_id.366--view_id.782024 .. Or item 18 in this view,http://www.volvopentastore.com/Gimb...on_id.853195591--store_id.366--view_id.783173
And the two O-rings for the input shaft item number 9,http://www.volvopentastore.com/Bear...*****.853195591--store_id.366--view_id.782027
Had you had an Volvo SX-A drive system then your O-ring would have looked like item number 8 covering the exhaust as well, http://www.volvopentastore.com/Gimb...on_id.853195591--store_id.366--view_id.775538
To help find/ensure the correct parts catalog for your drive, post the drive serial number, product number or full SX model number if you know it. How to identify your engine or drive
mtaboat
What seal the the two halves to keep water from the gimbal bearing?
I stole the above photos off the internet.
This is the info for my out-drive.
Volve Penta SX Cobra
Prod# 3868883
Ser# T0824512
Thanks
Fun Times
Post number 6 inside bajaunderground's link talks a little bit about where the drive shaft housing rests up against the U-joint bellows sealing out the water.
Prod# 3868883
Ser# T0824512
Being a Cobra/SX drive model, the product number tends to work better than using the serial number when looking things up under Volvo for better identification. Your drive is showing the drive to be an SX-M with a gear ratio of SX-M 1.60. < While that link will basically show only the upper and lower drive unit parts, Here's your complete list of parts such as the bell housing parts, etc, etc. once you click on Transmissions, http://www.volvopentastore.com/Marin...view_id.765160
Product Designation (Application)
Product Number
Technical Data
Product Name
SD1-A-AQ-17
Product Designation
SX-M
Part Number
3868883
Production Period
1998-1999
Gear Ratio
1.60000:1
Propulsor Type
Singleprop
Drag a column header and drop it here to group by that column
210459
Workshop manual
Poster - Sterndrive Models
(Only available in printed version)
23.7 MB
English
false
213959
Workshop manual
Workshop manual; SX-M, DP-SM
6.0 MB
English
false
219805
Product leaflet
Product bulletin 5.7GXI/SX Model year 01
74.2 kB
English
true
219847
Product leaflet
Product bulletin 7.4Gi/SX Model year 00
269.3 kB
English
true
seek-warrow-w
  • 1
  • 1
arrow-eseek-e25select2550100items per page1 - 4 of 4 items
