Eric Steinberg
- Nov 23, 2016
- 9
Greetings helpful strangers! I'm hoping some experienced folks might be able to look at the attached plugs and tell me what you think is going on. These are in a 1999 90hp 2-stroke Mercury. The engine suffers occasional misfires, which at idle or low rpms often stall the engine. This has been a nuisance problem for a long time, which has slowly escalated to severe nuisance status (considering ditching for a 4 stroke if I don't make headway soon).
I/my family have owned this engine since new. The block and head have never been touched. I have done the following "recently" to try to fix the misfire and plug fouling. This has been over the course of a few years, but only tens of engine hours... sadly I don't get to run this boat much.
1. New plugs
2. Rebuilt carbs (new gaskets, o-rings, etc... old stuff still looked pristine anyway)
3. Followed complete procedure in mercury service manual to sync and adjust carbs, linkages, and ignition timing
4. Measured oil injection pump output per service manual procedure and adjusted
5. New plugs (again)
Every trip starts and ends with 5-10 minutes of no-wake speeds. I have NOT done a comp test. The plug on the left is the top cylinder.
Thanks in advance!
1. New plugs
Thanks in advance!
