marine starter water tight?
iron21
hi, last summer during a couple days of HEAVY rain, my bilge started to fill with water and submerged my started and selenoid for about a day(89 3.0 merc)are these starters sealed well, or should i look to replace? its turning over fine now, but you know how it is, my luck i'll be out on the water and it will fail me lol... thanks
bruceb58
Re: marine starter water tight?
They are not sealed for water. I would pull the starter and at least dry it out. Mine got submerged for a week(forgot to pull a drain plug)and when I pulled it and took it apart it was pretty much junk already. <br /><br />I wouldn't go anywhere with a starter that has been submerged.
Boomyal
Take it to your local starter/alternator repair shop and have them go thru it.
Mine got Wet when My barge Sunk last year,....<br /><br />I Replaced it.........<br /><br />Now I've got a Spare Core on the shelf......
rob935
the same happened my 89 3.0l 2 years ago, it worked for a while but let me down badly when least expected, take it out and bring to get a bench test done may only need new brushes after getting a good drying out?? my advice though put a new one in and get old one reconditioned and keep as a spare you never know when you may need it ...good luck.
Bt Doctur
If it got that high I worry if any water got into the boot.
iron21
alright thanks guys...better to be safe then sorry
rodbolt
I am with Bt Doctor<br /> starter is the cheapest thing.<br /> if water entered the bellows from the engine side it cannot get out and WILL destroy some very expensive parts.
iron21
rodbolt: i'm confused..are you talking about exhaust bellows??
Bt Doctur
U joint bellows<br />vent hole in the housing about 3-4 inches below the drive shaft. water will go INTO the boot from a high level.if theres any doubt ,pull the drive and look.
iron21
ok gotcha..if indeed water did get in (about a year ago), am i looking at any damage when i pull the outdrive? and what kind, rusted up u-joints or something?
