shooter5636
Thread starter- Joined
- Aug 7, 2015
- 27
I've been back to searching for a motor after the '79 I checked out came up a dud.
I've been doing a lot of reading on outboard compression, but I can't seem to find what I'm looking for. I did a compression test on the motor cold and both cylinders turned 82psi on the dot. Motor started up super easy, idled great, and sounded healthy. The service manual for the motor stated that a specific compression range wasn't important. What is important is that both cylinders be within 5psi of each other. They are spot on.
If it were you, would 82psi of compression on each cylinder raise alarm?
