Please help!!! Mercruiser 5.7 Not starting Please help!!!
Alex57
Hello everyone, <br /><br />I am a begginer with boats but have some experiance with cars... <br /><br /><br />Just bought a '96 bayliner ciera with a Mercruiser 5.7 litter 2 barrel <br />carb Thunderbolt 5 Ignition <br />The thing ran fine for a while, then wouldnt start when hot and <br />eventually now doesnt start at all. <br /><br /><br />It cranks, turns over but no signs of life. I am getting gas for sure, <br />can see it in the carb. <br />I already changed the spark plugs, wires, cap, rotor. No change. <br />There is voltage going to the coil and continuity throught the coil. <br /><br /><br />There is spark comming from the main ignition wire (visible if you <br />touch ground) <br />There is also spark comming off the ignition wires (when you touch <br />ground) <br /><br /><br />When it did run, it ran just fine and I didnt't touch anything, so I <br />doubt it's the timing.. <br /><br /><br />SO I get gas, I get spark and nothing.... I am aware of the ignition <br />module/sensor and some kind of a changable ignition pick up sensor in <br />the distributor, but I have no idea how they work and wether they are <br />the problem. Me and my buddies are totally stuck. Anyone have any <br />ideas? <br /><br /><br />Any help would be greatly appreciate it.... <br /><br /><br />Thank you, <br /><br /><br />Alex.
QC
Re: Please help!!! Mercruiser 5.7 Not starting Please help!!!
You sure you don't have a fuel filter full of water?
Alex57
Thanks for your reply QC<br /><br />Filter? hmmm<br /><br />I did try starting with starter fluid and that didnt help...<br /><br />I didn't check that... Could that be it?<br /><br />which one of the two filters?<br />Is it hard to replace?
DayCruiser
Ensign
YOu should have a fuel filter between the gas tank and the fuel pump. Looks like a oil filter. If not then you may have water in the fuel pump and/or the carb
Don S
I'm not really sure rather you are checking the primary wiring or secondary, so try this.<br />Pull the center wire out of the distributor cap.<br />You will need to stick a screw driver in the end of the wire in contact with the metal clip. Then hold the shank of the screw driver about 1/2" from a good ground and crank the engine. You should get a bright blue spark that easily jumps that 1/2" gap. Touching the ground tells you nothing.
boathog
sounds like carb is flooding . may need float adjustment or carb cleaned out . try starting it at full throtle (keep your hand on the throtle) dont pump the gas.
marinemech1
be careful if boathog is correct<br />check oil for signs of fuel if fuel is in oil due to engine flooding don't try to start change oil
Alex57
Thanks everyone for your replies.<br /><br />I bought a spark testing tool and performed a test out of the mercruiser book.<br /><br />it said to plug the spark tool into ignition coil wire then unplug the distributor module and crank. According to the test, it's a failed ignition pick up sensor in distributor underneath the rotor. I will try to replace it and see if that helps.. <br /><br />THe oil is clean and full throttle start does not help. I will change the the sensor and let you guys know.<br /><br />THanks again.<br /><br />Alex.
michael-lagrange
--------------------------------<br />then wouldnt start when hot and <br />eventually now doesnt start at all. <br />--------------------------------- <br />Ignition problem.
I/O WALDO
Hang parts till it runs?
Don S
If you unplug the ignition module, of course you won't have spark. But that doesn't tell you anything about the sensor in the distributor. <br />Here is the troubleshooting chart. For the TB5 ignition. Follow it and do a retest before you replace that sensor.<br />What kind of "Mercruiser Book" are you going by?<br /><br />
Alex57
Don, that is exactly the chart I am using so it must be the same book.<br /><br />Where it says Reconect WHT/RED .... in thge biggest box in the middle. I did that. ANd there is spark. So if I am reading this correctly, that means I gotta replace the distributor pick up/sensor. I took it appart and will get a new one today. Hope that helps and the problem is not the carb flooding or something else...<br /><br />THe thing that bothers me about this test, is that although it makes sense... it's for a no spark condition. I think my spark is weak, but I do have at least some spark all the way down to the cilynders
Alex57
Hey Guys, <br /><br />changed the sensor... no change. Got spark, but then again I had spark before. :( <br /><br />After cranking it for a bit, I looked into the carb and maaaaan there is alot of gas in there..<br /><br />COuld it be the carb? flooding the motor? <br /><br />Funny thing, it's still dripping long after i stop cranking..<br /><br />THis has been a frustrating 2 weeks and no progress what so ever... :( <br /><br />Well looks like i will need a pro after all, but i will let you guys know what it was after I figure it our so this nonesense does not happen to you. :)
I/O WALDO
Lucky you didnt burn yerself up!! Carb Floodin! Get someone who knows SOMETHING about diagnostics to look at it b-four you hurt someone!(opinion)
Alex57
Thanks Waldo :) <br /><br />I mean flooding inside the manifold, not anywhere else.. proly needs a rebuild.
Alex57
Turned out to be a tight/jammed choke that didnt operate properly. The mechanic at the marina tuned the carb, fixed the choke and had me ready to go in about 5 minutes....<br /><br />Moral of the story when in doubt, check the choke operation thouroughly.<br /><br />thanks aeveryone for your replies.
