89 johnson 7o hp heavy oil on 1 plug
rbass1957
89 J70TLEM RUN GREAT,THEN SOUND LIKE COMMING APART (sorry) at wot ,dies starts back up ruff sound,knock,peeing fine but notice no water out 2 little exhuast holes in back of motor,pull plugs,lots of oil on bottom plug ,strong gas smell and look wet,will staart but only low idle,will not throttle up.been suspecting carb trouble lately,chime in please and help this fellow boater,i need a direction to go in ,thank you ..rbass1957
The trouble shooting on an outboard starts with a compression test.-----Always the #1 thing to do.----Just post the values you get.
jakedaawg
Welcome to the forum. If you follow racerone directions to a tee you won't go wrong.
rbass1957
will check and get back to you ,might be a day or 2 ,thank you ,how do i follow this post so i dont have to look it up, subscribe?
GA_Boater
Welcome aboard rbass1957
Click on your username on the top of the page and then click "My recent posts".
rbass1957
not good comp,90-95-10,where do igo now ,rebuild,was good motor,thanks
flyingscott
None of those compression #s are good. Take the head off and see what you can see, Maybe a bad head gasket, you can always hope. But I think a teardown is in order
Pull the cylinder head off.---Just a few bolts to take out.
rbass1957
thanks guys ,later today i will take head off and see what it looks like ,rbass1957
rbass1957
bottom one burnt up,i can send picture to phone,but cant put it on here,other 2 look ok,first time i have ever pulled the head on one ,lol,have fished since i was 5,had a few motors in last 35yrs
rbass1957
could someone tell me a ball park figure on bore and rebuild? thanks for all the help
Are you doing the work yourself ?-----I bore my own blocks.---Shops will charge up to $100 or more to do 1 hole.
rbass1957
no,not me,im not qualified,lol. im guessin 15oo to rebuild,am i close?.older motor worth a dang a hard to come by,my last one was diamond in the ruff. i can send u pic of burnt piston,pm me.thanks again
I know what " burnt pistons " look like.---No need for a picture.----At a shop you are likely looking at $2000 or more to do that kind of work.---Fewer and fewer shops around that will take on work of that nature.
rbass1957
thank you for your time,opinion on johnson tracker pro series motor,70hp,1989 model,is good motor/?
Sirrobin53
Good to hear you found a motor. Keep us posted after installation and testing. I always like happy endings. ;-)
rbass1957
? for those who know. looking at 91 johnson 70 hp. all of my parts from 89 model fit this motor as well? thank you all..rbass1957
