jedimaster
Thread starter- Joined
- Jun 8, 2006
- 336
Hey, ok so I had one piston melt on a 2002 225 HO Ficht with about 300 hours on it. I pulled the head and the cylinder looks good. A hone job should be good enouch, I shut it down the instant I heard something rattle so damage was fine. I'm not too worried about the mechanical of the rebuild that I can do no problem. My question is what happened. The Plug was showing a lean condition so would you say this is a condition of that ficht pump gone bad? Is there a way I can Bench test it now that its off? Also has anyone used something like this to read the Codes and replace an injector if need be? http://www.ebay.ca/itm/PROFESSIONAL...t-EMM-diagnose-restoring-update-/190868940025
If you have any other ideas on what I can check and look for as a cause please I'm all ears. Right now I am just continuing to tear down the motor to prep it for a rebuild.
