Brass Drain Plugs ??
No. for years all that existed were 1/8npt and 1/4 npt. however you have to pull the adapter out of your block as well. in your pic, only the left most one has the adapter.
FYI if you get the brass NPT plugs from either your local industrial supply house, industrial plumbing house, or mcmaster carr or grainger, its even less expensive than home depot
https://www.mcmaster.com/#brass-pipe-fitting-plugs/=14up9j2
shaw520
No Title
Nice! ,.. thank you Scott,.. good savings ! Im getting the twins ready for their winter nap. Motors are flushed and fogged,.. blocks and manifolds are drained,. some new brass plugs will go in,.. then the outdrives are coming inside for service and paint.
Rick Stephens
+1 to Scott.
I replaced all of mine with solid brass plugs from local Ace Hardware.
Ayuh,..... Don S convinced me to do the same, years ago,...
shaw520
Yup,... im a believer too,... just bought (8) 1/4" square head, brass plugs from local hardware,.. $1.67ea !, ..would of preferred hex heads but at that price im not fussin".
Rick Stephens
Didja get a square head socket for them while you were there?
shaw520
Yea,. I have 8 pnt sockets that'll work. TY
Ayuh,.... 12 pt sockets are quite common, 'n also fit 4 pt heads,...
