Tony T.
Thread starter- Joined
- Jun 5, 2007
- 178
Ok my 12v Shurflo pump (newly replaced a couple years ago from the orginal) runs and pumps but is not working right. Here's whats happening fill up 1/2 full 40 gallon storage tank, turn on 12v pump and it continues to run which indicates a leak, found the leak, it's pumping water back outside through the "city" connection. Also if city water connection hose is hooked up, it's bypassing and filling up the 40 gallon storage tank. Does this mean the diaphragm in the 12v pump is bad, because I'm thinking that it has a one way flow check valve. This 12v pump is installed on a 28ft Prowler Travel Trailer.
Thanks for any information.
Tony
Tony
