- Jul 18, 2011
- 19,543
Sunday update . . .
I decided that the wobbly trash barrel was not such a good thing to be running the motor in, so I decided to build a motor stand. Three 2x4's is all that it took.
I was wondering if the idle speed that I set yesterday was gong to be OK. I happened to find a manual of a newer 8 hp Merc that had a spec for the idle setting . . . 850 RPM in gear.
So, I ran the engine some more today (with motor stand) and checked the idle both in neutral and in gear. Neutral is about 1100-1200 as I had posted yesterday, and in gear it is about 900 RPM. So, it should be fine. :thumb:
The engine seems to be running very well, but I won't be able to give it a full testing until boating season begins . . . still about 3 months away.
I do need to clean the motor up and apply a final coat of paint, then add the new set of decals.
