- Jul 18, 2011
- 19,644
Quick Update - Salt/calcium cleaning
I got some salt eliminator to clean out the water jackets and side panel of the powerhead, while the engine is apart. One area in particular was the 'Flush' tube and plug fitting.
I had not been able to remove the Flush Plug since I have owned the engine (about 3 years), but I wanted to see if I could get it back into annual operation. The impact driver did a nice job in loosening the plug. The calcium/salt was packed solid inside the flush tube. The salt 'impaction' extended about 2" up the tube. I drilled out most of it from the top of the housing, but the drills that I had would not go all the way to the plug fitting. There was about 1/4" of hardened salt remaining, which blocked the tube. I poured salt-away in the tube and let it sit overnight - still nothing. I used some light drilling in the fitting end to see if I could 'break through' to the other side.
Finally, I got a right angle scribe and worked into the salt, which was more like sandstone and got the flush tube cleared. :thumb:
I guess I should make the salt flush and annual event going forward
As for the powerhead and overall engine assembly, I still have to remove the remnants of the gaskets from all of the mating surfaces. That seems to be more difficult than the salt blockage
Any tips/tricks there on gasket remnant removal? :noidea:
