CPO Hazard
Thread starter- Joined
- Sep 15, 2016
- 10
Evinrude 1972 Fastwin 18HP owned for about two years. Just rebuilt and cleaned carburetor, adjusted the low speed needle according to the manual, replaced all fuel line and filter, and replaced spark plugs. Before all that, she would idle good, but would just shut down at full throttle. Now she idles great, but started to sputter, cough, and choke out after running her at FT. The pattern today was idle in the channel for 10 minutes, FT across a little lake for 5 minutes, then idle for 5 minutes, and finally FT on a large lake (Minnehaha in central Florida if you know it). She did her sputter, cough and choke right in the middle of the lake. Awesome! I was able to get her started and check out under the cover. She would cough, almost like a skip. Nothing grinding or pinging. Fuel is going in. 50:1 mixture. Plugs are new, gap is perfect, and compression by finger check is solid in both valves and feels equal. The original pressure a year ago was hitting about 110. Any ideas?
