1999 Johnson 15hp outboard help
Ddflemi85
Thank you for allowing me to allow to join your forum. I am having issues with my outboard and I am about to give up and desperately need help. My outboard will only idle and run if the idle is turned up. This happened before and it was my carb so I put in a new carb kit and it didn't fix it. Since then I have put fresh fuel, new spark plugs, new fuel pump, new hose connections and put in another carb kit hoping i installed the first one wrong. Does anyone have any ideas? Am I missing something in the carb. I don't want to just buy a new carb because they are very expensive but that is all I can think of now. I thank you in advance for any recommendations.
Darryn
Why blame the carburetor?----Do a compression test and check for strong spark on each lead.
Ddflemi85
Ok I will do that today if I can find a compression tester. On the spark plug test do I just ground the body of the plug to the frame?
flyingscott
No buy an open air gap tester can be bought for less than $10 and set it to 7/16" healthy spark should jump that .
fireman57
You said it was your carb before, did you clean out the jets well? Soak the carb and blow out with compressed air?
Ddflemi85
So I checked the spark and it was strong. Cylinder pressure was 60 psi. I guess I need to check the carb again.
thatone123
Banned
Cleaning a carb and cleaning a carb are 3 different things. Many times cleaning it properly is what is the matter, not a carb kit all the time...They really need to go very long hours, (thousands) to wear out a carb. I've re- cleaned many until I learned to do it right. If very old and dirty it needs a dunk or ultra-sonic cleaning, not just carb spray. You need to be meticulous with the cleaning sometimes. Sometimes those aluminum plugs need to be taken out also. Not often.
Ddflemi85
Thanks for the info. I must be missing a passage somewhere. I will give it an ultra sonic bath tomorrow and hopefully that will work.
flyingscott
Yes that compression seems low for that motor. I would expect it to be at least 90 psi and above. Since they are both the same just get a different gauge.
