Folks,
Due to some cooling issues I decided I would do the head gaskets (and water jacket covers) on my 1990 115hp V4 Evinrude and clear out all the water passages at the same time.
However being half way through I have a few questions I am seeking some help with.
1. I have to replace one of the heads due to corrosion. I managed to source a replacement however it has previously been on a motor that threw a ring and the TOP surface of the head has sustained some damage where the remains of the ring crunched into it. The walls are fine and the mating surface is fine. I have cleared up some of the damage with some sand paper however I am concerned that if I do use this head I might be causing more problems for my engine. I have attached some photos. Advice ?
https://drive.google.com/file/d/12gTkhGNClUGM1AHx5enU-lW1xqf-y5dLNA/view?usp=sharing
https://drive.google.com/file/d/1znchFz3OFJTVdMs74nsNaEtRFLA0IlJFmg/view?usp=sharing
2. I am trying to do the heads without removing the powerhead from the motor. The starboard side is easy to do but the port side looks like it will be difficult to get a torque wrench down to the bottom bolts. Since the service manual advises that you need to re-torque after running it in a little I am confused how you would do this even if you did remove and refit the powerhead. Is doing the head gaskets on this motor possible without removing the powerhead ?
3. The service manual says to use gasket sealant on the new gaskets. The ones I have seem to have a tacky coating out of the pack and from what I have read this is a seal-sealing compound. As such should I use these gaskets without the OMC sealant ?
Matt
Matt
