mechanically
Thread starter- Joined
- Aug 21, 2016
- 7
I have replaced the impeller, new head gasket, rebuilt (to the best of my ability) the carb, new plugs, and rebuilt the fuel pump.
This engine has sat for at least 20 years.
Upon opening the head, here's what I found.
I cleaned out the "mud" that was in the water space around the cylinders.
Tonight I finished the fuel pump, and hooked everything up. It took me a LONG while to get it started since I wasn't sure where the needles in the carbs should have been, so had to keep experimenting until I got it going.
I think I got it going pretty well.
It's in a drum with everything below the "shelf" above the prop submerged.
When it's running, the exhaust holes "spurt" water out. They certainly don't spray water continuously. I have no idea if that's normal.
Once I got it up to what I feel like was WOT, I ran it for between 45-60 seconds. Then poured just a little water on the head. It boiled. I grabbed my phone, and did it again while recording:
This is way too hot, right?
<iframe width="420" height="315" src="https://www.youtube.com/embed/HfxIsHkAeeE" frameborder="0" allowfullscreen></iframe>
Any thoughts on where I need to address the cooling system? I have a feeling something between the impeller and head is still blocked...
