Copilottruman
Thread starter- Joined
- Aug 23, 2016
- 15
Thanks in advance for any help. Last week on the way back in from a fishing trip while at full power my outboard out of nowhere started bogging down and then soon after cut out. The sound it made when it died was similar to the time it died a week before that. However the first time it died it was remidied by unscrewing the fuel tank vent all the way. This time that didn't work. The engine will now only stay started when I rev it up in neutral but when I lower the rpms to put it in gear it dies. Thinking that something might have gotten sucked into a carburetor jet I removed the carbs and took them apart spraying them down with carb cleaner and compressed air and reset float heights (per other iboats topics). After reinstalling them, cleaning them did nothing to help the problem. Some other things that I've checked are:
My idle adjustment screw is all the way in.
The primer bulb gets hard and stays pretty hard after running. When I hit the electric choke when running it dies.
The fuel pump screen is completely clean.
Fresh gas.
New plugs within the last month.
I'm at a loss on what it could be and the engine was running great and started right up every other trip. I'll post a video of what it sounds like on a pair of muffs.
https://youtu.be/k1oHwZX0Csw
Fresh gas.
