crowrivercat
Thread starter- Joined
- Aug 7, 2016
- 6
1972 65 hp johnson. what could be the problem it runs and shifts fine but when i give it some throttle it kicks outa gear when i let up it goes back into gear
Welcome to iboats
You say it jumps out of gear when some throttle is applied? What is some? Wide open, half, just move the throttle a hair? Does it stay out of gear and rev up, or does it jerk in and out of gear? That shifting system uses oil pressure to into neutral and reverse and defaults into forward when not running or when power to the case is lost. Have you ruled out a slipping propeller hub?
Welcome to iboats
72 was the only year for an electric shifted 65 hp motor.
You sure it is a 72? Disconnect the shift wires. either at the remote or under the cowl. 2 wires with covered knife connectors, one green, one blue. Be careful when starting it, as it should be in and remain in forward.
Mine has the shift diodes. Purple/Green is on #4 of the terminal block. Yellow/Gray is on #2 and Yellow is on #1When then a bit of troubleshooting/detective work is needed. Let's see what happens disconnected. I don't think your engine has the shift diodes. I think it has a vacuum switch in their place , but it does have the blocking diode in the control box.
