Is this normal or not? (ficht ram 115 2000)
Jonter0
Hi My friends Evinrude is making this knocking sounds when the flywheel is moved back and forth
https://www.youtube.com/watch?v=X79IxoNejyc
So is that normal or have the bearings broke down?
The engine wont rev over 2300rpm when under load but when the gear is on neutral it will rev over 5000rpm
Two lower cylinders have spark but the spark plugs are pretty black and soaked, two upper cylinders plugs looks just fine.
Spark plugs are new and indexed.
flyingscott
Either your flywheel is loose or you have a bad bearing. Revvng in neutral Means NOTHING. You are kind of at a cross roads here fix or replace. My opinion would be replace, parts are getting harder to find because BRP is not really supporting any of the FICHT motors. And parts are expensive.
Jonter0
Thanks for your input, I know it means nothing revving on neutral I just wanted to tell that the motor is not in safe mode or similar to that.
I do a few more tests on the motor before I tell my friend that the motor would probably work better as an anchor
Jonter0
Problem solved!
Crankcase had gotten loose and broken in two peaces... The lower part of the crankcase.. kampikammio.jpg
