Mercruiser 3.0 engine alignment
EBRAMS
I just replaced my Gimbal Bearing and when I checked the alignment I was only getting marks on the very top of the tool ... No big deal right I'll drop the front of engine down when i attempeted to do this I noticed that the front mount was already as low as it will go so i started checking the rear mounts took the bolts out and took some pictures can you guys take a look and tell me if you think the rear mounts dropped or if you think the springs are to compressed
Thanks Mark
achris
More fish than mountain goat
Those 'springs' are meant to fully compress. I can see what looks like one rear mount standing a little higher than the other, or is it an optical illusion?
Chris.....
EBRAMS
Yes I was thinking the same thing but I really couldn't tell. I only took one spring out and looking at that it doesn't look like it will compress any more than a piece of paper so I'm not sure if my problem is the spring or it's in the mount but I can tell you for sure that the rear bellhousing what setting on the fiber washer
Ayuh,.... Welcome Aboard,.... Sounds like a bad mount,....
EBRAMS
So I guess I need to order pn 8M0103028 which is the rear mount kit. Now looking at the picture of parts
shows a spacer does this spacer get installed on top of the mount before it gets pressed in to the bell housing. also does anyone have any literature on installing the new mounts
Thanks mark
Alumarine
PM me with your email and I'll send you the installation sheet for the new style.
or
If you google "Bulletin No 2003-11" or "90-865505001" you should gets links to the install sheets as well.
EBRAMS
or
Got your email thank you
EBRAMS
Ok next? I see there are 2 different part numbers for the mounts is the only diffrence the color of the dot on them?
Alumarine
My instructions indicate 865329A02 with the white dot were for Alpha's and Bravos while the 865330A02 with the yellow dot were for Bravo's only.
The mounts are different, that's all I know. I ordered part 8M0103028.
achris
The new mount kits come with instructions.
EBRAMS
You are absolutely right I am sorry I missed that
EBRAMS
Yeah looks like the 8M0103028 are for the heavier engines..
EBRAMS
Ok please i need help!! I installed the rear mounts ( the new style ) and i still have to force the alignment tool in and it does not go all the way the tool is showing that the front still needs to come down but its down as far as it will go. the rear mounts where installed with the ruff ends down I put the spacers in the bore then I pressed in the mount. installed the fiber washer and metal washer between the transom and the bell housing ears. then installed the the spacer on the of the mount then the metal washer on top of that ..... Where do i go from here
Alumarine
Have you rotated the motor in 90 degree increments to see if that changes anything?
EBRAMS
Yes I have rotated the engine.... before I tightened the rear mounts down and the engine was just setting on the mounts the alignment tool went on easy I belive if i put another set of washers in the rear it would take care of the issue but not sure if that is acceptable.
Speak
Thanks Mark
Am I missing something. If you have full contact on the top of the tool, wouldnt you want to raise the front of the motor?
