Capt'n Caution
Thread starter- Joined
- Jul 16, 2016
- 23
The actual weight on the towing ball is 125 lb. The boat and motor and galvanized trailer, all brand new, now gross at 600 lb. The trailer max gvw is 1500 lb. I have the 15' alu jon transom an inch forward of the bunk rear ends. I cut 3' off the tongue to save 30 lb. I do not want to install stronger bunks and push the boat further back. The spring hangars are welded to the frame and then all is hot dipped galvanized. The 10 hp motor weighs about 80 lb. less that the weight of the 25 hp motor allowed on this boat. Any gear will put more load on the ball as the axle is only 2.5' ahead of the transom of the boat and everything will have to be loaded forward of the aft seat except for the gas tank. I have read about bolting a heavy steel bar across the back end of the trailer frame. This would reduce tongue weight and also soften the hard ride. Has anyone got any experience with adding an 80 lb or heavier weight like this?
