ksbhjohnson
Thread starter- Joined
- Aug 24, 2012
- 11
I recently upgraded boats from one that had a 1993 OMC 3.0L motor and outdrive to a 1999 Four Winns Horizon 180LS with a Volvo Penta 4.3L motor and outdrive. I notice some differences in the way the temp gauge reads between the two boats and just want to make sure I do not have a temp issue with the new boat. On my previous boat, the temperature would rise (never overheat though) as I was going across the lake (accelerating) and would drop back down after slowing down or just sitting at idle for a bit. On the new boat, once the engine warms up it stays at about the 3/4 mark of the gauge and does not fluctuate at all regardless of the speed of the boat. Neither of the gauges provide an actual a temperature reading and just show a range between hot and cold. Is the new Volvo Ok or do I have an issue? For what its worth the impeller was replaced in 2015.
Also, I have ordered a temp gun just so I can reassure myself and check some true temps at the motor. At what points on the motor should I take readings?
Thanks in advance for the help.
