My outdrive just started slipping. I changed my prop to a higher pitch and it started slipping went back to old prop and it's still slipping. Cable is adjusted correctly. Is the drive toast or is there something I can do to adjust it?
No smell of burnt rubber from coupler. Prop hub is new and I looked at it it had not spun. If the gears broke or something like I would hear that. The smell if caught whiff off was maybe gear oil. This once before 2 years ago changed engine coupler and still did it. Then all of sudden it just stopped till I put on a new prop from 15.5x17 to a 14.5 x21. Then it started again so I stopped the boat changed back to old prop while in the water and it still did it. So you are saying there are no clutches of any kind that could slip. Only gears? I think my boat has gremlins. It's a 25DA searay 1990 rebuilt motor this season approx 375hp 7.4l
Yes. First it is a 7.4l and in another thread he asked about a B1 to B2 swap.Have we determined if the OP is refering to an Alpha or a Bravo drive?
My regal with the 7.4L seems to the do the same thing. Is there a video or how-to on flipping the cone clutch gears?Flipping the cone clutch and gears is not really all that much work and it is quite effective at fixing this issue. As stated, you never use much throttle in reverse so you can use the less effective clutch there and get double the life out of the gear/clutch sets.
