Need help identifying model number of an Evninrude 90
James0816
Got a call from the service shop asking for the model number of my motor. They said the tag had been painted over. I look on the title and it only lists a serial number. Is there any other way to find the model number of the motor? They need the model number to order the correct carb kits for it.
any help is greatly appreciated.
thanks kindly
interalian
V4 carb kits cover a very wide range of years and include many parts that aren't required depending on which year. Picture of the motor would get you in the ballpark.
Chinewalker
Scrape the paint off the tag? Also should be on the welch plug on the top of the cylinder block - unless the powerhead has been replaced at some point.
James0816
No Title
best pic I have at the moment.
James R
Not a very smart outfit if they cant identify the carb type assuming thats all they are looking for. As stated the kits cover a wide range of carbs. Serial numbers dont help much. Provide pics of the carbs and that might help.
interalian
I was going to say that, but didn't want to impugn the shop's reputation. That said, so many shops these days don't even want to touch motors that are more than a few years old it's no surprise they can't identify something that looks to be late '80s. My local place says they won't touch anything older than 1995 even though the owner has a mid '70s 140 with jet drive on a bass boat that he says he loves to drive and work on.
82rude
Some parts people today are number and computer fixated.Went to a local dealer and asked for a omc throttle cable .No could do unless he had a model number.I had to take him by the hand and show him the used for 30 years omc cable that works on almost every erude and johnny.Yet other parts guys and girls are walking fountains of parts knowledge.
James0816
they said the cleaned up the motor a bit and found a secondary label on the starboard head. whatever that means but i'm guess there is a plate on the motor block somewhere.
Chinewalker
That would be the welch plug I mentioned...
82rude
I think id be getting my motor from these guys,they sound a little lost to be polite.
82rude
FROM the beginning of the 90 hp to 1996 the same carb kit was sold for all 90,s oem 0439076
jimmbo
thanks kindly
There are many things that will lift the paint that any shop would have Brake fluid is one
jakedaawg
Just out of morbid curiosity please post back when you get it back from the shop and let us know if they did a good job. It is quite possible that the mechanic could be excellent and someone else there just doesn't know anything without a model # to work with.
